Дата: 12 Дек 2010 21:39:05 · Поправил: kooldima (12 Дек 2010 21:40:23)
подкажи где найти пару записей кодограмм, ну что то вроде:
all station, all station, this is Andrews, Andrews break... adjffa adjffa adjffa... msg flws... adjffa fehfbksjdbazsdbv... this is Andrews out
а если найдется то и на пару сотен знаков=)
Дата: 12 Дек 2010 22:24:02
kooldima
Такая подойдёт ?
00000010101010000000000001010000010100000001001000100010001001011001010101010101 01010010010000000000000000000000000000000000000110000000000000000000110100000000 00000000000110100000000000000000010101000000000000000000111110000000000000000000 00000000000001100001110001100001100010000000000000110010000110100011000110000110 10111110111110111110111110000000000000000000000000010000000000000000010000000000 00000000000000000010000000000000000011111100000000000001111100000000000000000000 00011000011000011100011000100000001000000000100001101000011000111001101011111011 11101111101111100000000000000000000000000100000011000000000100000000000110000000 00000000100000110000000000111111000001100000011111000000000011000000000000010000 00001000000001000001000000110000000100000001100001100000010000000000110001000011 00000000000000011001100000000000001100010000110000000001100001100000010000000100 00001000000001000001000000011000000001000100000000110000000010001000000000100000 00100000100000001000000010000000100000000000011000000000110000000011000000000100 01110101100000000000100000001000000000000001000001111100000000000010000101110100 10110110000001001110010011111110111000011100000110111000000000101000001110110010 00000101000001111110010000001010000011000000100000110110000000000000000000000000 00000000001110000010000000000000011101010001010101010100111000000000101010100000 00000000000101000000000000001111100000000000000001111111110000000000001110000000 11100000000011000000000001100000001101000000000101100000110011000000011001100001 00010100000101000100001000100100010010001000000001000101000100000000000010000100 0010000000000001000000000100000000000000100101000000000001111001111101001111000
Без шуток, реально. Разгадаете - будете супердешифровальщиком.
Дата: 13 Дек 2010 09:28:29
Фотограф а чего это за абракадабра?
Дата: 13 Дек 2010 09:51:15
Послание особо одарённых Землян инопланетному разуму.
Дата: 13 Дек 2010 14:59:01
и ничего смешного. polohat на 22 знака что ли не разу не слышали? много потеряли=)
Дата: 13 Дек 2010 16:11:11 · Поправил: RadioKoteg (13 Дек 2010 22:47:15)
Послание особо одарённых Землян инопланетному разуму. ага, значит я не инопланетный разум, я вспомнил, это насовская хня, вот она http://space.my1.ru/_pu/4/26392.gif .
Добавил:
Аресибо слал такое, проект "сет`и" после этого попёр во всю. |
Дата: 13 Дек 2010 16:14:06
kooldima
О-ба-на! Ни-ког-да! Брат, поподробней, будь ласка. Это типа шляпа?
Дата: 13 Дек 2010 16:15:19
RadioKoteg
Там после ссылки точку уберите, а то не открывается картинка с нею.
Дата: 13 Дек 2010 17:03:48
vrn7234
Совершенно верно !
16 ноября 1974 года с самого большого радиотелескопа Земли в Аресибо (эта 300-метровая сплошная параболическая антенна все еще остается самой большой по площади) в направлении шарового скопления M13 в созвездии Геркулеса было послано первое послание земной цивилизации. Оно передавалось на частоте 2380 МГц в течении 169 секунд и содержало 1679 битов информации (нулей или единиц). 1679 = 23 x 73 (причем и 23 и 73 - простые числа). Если "декодировать" это сообщение - разложить в прямоугольник 23 на 73, то получится картинка
А если провести разложение по другому - 23 строки по 73 точки - то ничего осмысленного на получится. |
Дата: 13 Дек 2010 17:46:56 · Поправил: RV9WMV (13 Дек 2010 18:02:24)
Как-то в одном журнале, емнип "Знание-Сила", писали (академики!) красивую аналогию насчёт этих посланий в неизвестное. Типа мы кричим: "А вот оно мы! Придите и съешьте нас". Смысл в том, что лучше было бы помолчать. И примеры приводились из серии астронаблюдений, что такие попытки "пошуметь в эфире" как-бы были фиксированы земной техникой, и быстро заканчивались, из чего стоит сделать вывод (как в анекдоте притче про замёрзшего воробья и тёплую коровью какашку) "если попал в тёплое место, сиди и не чирикай"
Читал подростком еще, так что передаю приблизительно общий смысл. Кто тоже читал это, дополните плз
Дата: 13 Дек 2010 21:20:47
Где подобное я уже видел. Ах да!!! В "Ворде", на тему "9-11"
Судя по количеству сообщений в профиле, и соблюдению Правил форума "подскажи(те)" парнишка опечатался в адресной строке.
Дата: 13 Дек 2010 21:48:45
Наши адресаты должны догадаться, что это неспроста: по-видимому, для расшифровки надо применить «телевизионную» развертку изображения, состоящую из 23 строк по 73 элемента в строке, либо из 73 строк по 23 элемента. Чтобы сделать это изображение наглядным, будем каждый «0» изображать черным квадратиком, а каждую «1» — белым. Тогда получим изображение, показанное на рис. 1.14.2. Оно соответствует второму варианту (73 строки по 23 элемента) и носит явно не случайный характер (если принять первый вариант «развертки», то никакой «осмысленной» картины не получается). На рисунке справа дана расшифровка послания. В первом ряду двоичным кодом изображены числа натурального ряда от 1 до 10. Второй ряд — это метки чисел. Третий ряд содержит числа: 1, 6, 7, 8, 15; это — атомные номера водорода, углерода, азота, кислорода и фосфора— химических элементов, лежащих в основании земной жизни. Затем следует 12 групп, каждая из которых состоит из 5 элементов — это молекулы, важные для жизни и состоящие из указанных выше элементов: числа изображают химические формулы этих молекул. Например, 5-я группа не содержит атомов водорода, углерода и азота, а содержит 4 атома кислорода и 1 атом фосфора, следовательно, это фосфатная группа РО4. В число важнейших молекул включены 4 нуклео-тида: тимин, гуанин, аденин, цитозин (с помощью которых осуществляется кодирование наследственной информации), молекула сахара дезоксирибозы и др. Под этими группами изображена двойная спираль ДНК (6-й ряд). Число нуклеотидов в ДНК (около 4 млрд) изображено в центре спирали — 5 ряд. Ниже — фигура человека. Поскольку двойная спираль заканчивается на схематическом изображении человека, это, по замыслу авторов послания, должно указывать на связь ДНК с разумными существами, передававшими послание. Справа от фигуры человека изображено число 14, указывающее рост человека. За единицу длины при этом принимается длина волны радиоизлучения, несущего послание. Она равна 12,6 см. Таким образом, рост человека здесь равен 12,6 см х 14 = 176 см. Слева от фигуры человека число 4 ∙ 109 — численность человеческого рода на момент отправки послания. Ниже (в 10-м ряду) изображена схема Солнечной системы. Видно, что она содержит 9 планет. Третья планета выделена из общего ряда, что указывает на ее особую роль; поскольку она приближена к человеку, можно заключить, что именно на этой планете обитают разумные существа, отправившие послание. Наконец, в самом низу изображена схема радиотелескопа Аресибо и указан его диаметр — 306 м. |
Дата: 13 Дек 2010 22:11:57
RV9WMV
Может быть... Только послание, о котором идёт речь, ещё не дошло до адресата !
Дата: 13 Дек 2010 22:36:22
RV9WMV
да в курсе я, что такое скорость света и что такое астрономические расстояния, не в том дело. Если правильно помню содержание той самой статьи, смысл в том, что астрономы неоднократно якобы фиксировали всплеск радиоизлучения, потом еще всплеск гамма через сколько то (помните Звезду Смерти из звёздных войн, как она с планетами поступала) и потом, тишина. Я вас не пугаю конечно же, просто привожу, фрагментами, ту самую статейку. Я всё понимаю, звучит дебильно - но сама мысль о том что вякать о себе лишний раз не стоило, мне показалась весьма убедительной. Особенно по аналогии с тем, о чём мы хоть как-то можем рассуждать - с нашей собственной Природой на планете Земля.
Дата: 14 Дек 2010 02:04:55
Вот представте муравья с фонариком который мигает, что с им будет? Да его попросту раздавят. Вероятность того что он помигает в глаз "муравьёлогу" равна почти нолю. Так и с нами будет. Да и пока сигналы куда-то дойдут то нашей земли не будет. Или возьмите просто крикните в эфир, например на частоте пару Гигагерц, вероятность того что нас заметят земляне в большущем городе тоже равна нолю. Надо кричать на тех частотах где полно слушателей, а мы к сожалению не знаем где у "потудышнего" разума "шестерки" "двойки" и всякие "сороковки".Вот так я отношусь к "айресибовской" выходке.
Дата: 14 Дек 2010 13:28:32
RadioKoteg
Зря они вооще такую картинку отослали. Надо чего-нить было более приземлённое: ну там смайлик какой, пивка бутулочку, фотку какую с журнала типа Hustler, ну и т.д. Спектр, имхо, широк :-). Надо, тык сказать на народные инопланетные массы ориентироваться, а не на МЕГАМОЗГИ. А то получит вот сообщения какой-нибудь ZABUBELLO (это ник, так, навскидку, что в голову пришло), не прошарит и выкинет его. А вот если то, про что я написал, сразу всё ему ясно станет. И откроет на тамошем "Сканере" веточку... :-)
Дата: 14 Дек 2010 15:41:16
MAMADU
Были и другие "картинки".
В бумажном виде ? Или с инструкцией на ZABUBELLOвском языке, как эту картинку "вытащить" из радиосигнала.
Дата: 14 Дек 2010 16:35:37 · Поправил: Антиквар (14 Дек 2010 16:45:37)
Посылать такие сообщения - дело неблагодарное. С большей вероятностью будет прочитана записка, вложенная в запечатанную бутылку, и брошенная посреди океана. Радиоастрономы принимают радиоизлучение таких источников, как пульсары и квазары на очень большом расстоянии, но лишь потому, что мощность этих источников колоссальна по сравнению с суммарной мощностью всех передатчиков Земли. Земляне, чтобы их слышали не только на ближайших звездах, где вероятность существования планеты, пригодной для жизни, весьма мала, должны либо создать передатчик циклопической мощности, либо использовать остронаправленные антенны. Но при этом сильно сокращается потенциальная "целевая аудитория". Далее, возникает проблема выбора частоты, вида кодирования сигнала, содержания послания, того, чтобы сигнал резко отличался от "естественных", природных радиосигналов)...
Но самая большая проблема - низкая вероятность того, что даже на обитаемой планете существует цивилизация, занимающаяся постоянным мониторингом радиоэфира в широкой полосе частот с целью обнаружения инопланетного послания. Допустим, Земля существует ~4 млрд. лет. Многоклеточная жизнь на Земле существует менее 1 млрд. лет. Развитые млекопитающие - менее 100 млн. лет. Человек - менее 1 млн. лет. Человеческая цивилизация - не более 10 тыс. лет. Радиосвязь возникла чуть более 100 лет назад. Радиотелескопы появились чуть более 50 лет назад. То есть, лишь (50/10^9)*100% = 0.000005% своего времени земная жизнь способна принимать внеземные радиопослания. Разумно предположить, что это справедливо и для внеземной жизни, если она существует. В этом случае получается, что, чтобы с вероятностью 1% наше послание услышали, надо передать его так, чтобы оно достигло 200 тысяч планет, на которых существует какая-либо жизнь! И это - если считать, что сообщение со 100% вероятностью будет принято цивилизацией, имеющей радиотелескопы.
Если считать, что наше радиопослание наверняка будет принято лишь на одной из двух миллионов планет (!), на которых есть жизнь, то выводы неутешительны (или утешительны, если смотреть в небо со страхом, ожидая оттуда вторжения агрессоров). В нашей Галактике, скорее всего, не найдется даже одной планеты (кроме нашей), на которой есть жизнь, способная услышать наш радиосигнал. То есть, нужно посылать сигналы в другие галактики. Это совсем другие расстояния, другие мощности. Даже если послать такой сигнал, его смогут принять лишь через миллионы лет. Возможный ответ придёт еще через столько же времени. Увы, масштабы Вселенной таковы, что вероятность пообщаться с "братьями по разуму" исчезающе мала. Практически это значит, что человек одинок во Вселенной. Если "световой барьер" непреодолим, точнее, если невозможна "телепортация", человек не сможет и путешествовать во Вселенной (не считать же серьезными успехами в освоении космоса полеты на другие планеты или даже на ближайшие звезды), то есть, он окажется привязан к своей планете, максимум - к своей звезде.
Дата: 14 Дек 2010 16:40:55
А психология это вообще надстройка над разумом. Правы были наверно братья Стругацкие - мы с ними скорее всего ходим один поперёк другого, просто не видим друг друга (парадокс). У животных есть разум. Пчёлки, муравьи, птицы, киты, кошки, да кто угодно. Нашли мы с ними общий язык? При наличии всего компьютерного парка? Что уж тут говорить про то что создалось в других мирах?? ))
Для общения, как минимум - должны быть общие интересы с обеих сторон.
Дата: 14 Дек 2010 16:47:09
С домашними животными - отчасти да.
Дата: 14 Дек 2010 16:49:32 · Поправил: RV9WMV (14 Дек 2010 16:53:38)
Потому что есть с ними симбиоз общие интересы.
добавлено - (польский анекдот) - Встречная собачка спрашивает Песика Фафика - "Чё делаешь?" - "Не видишь чтоли? Хозяина прогуливаю!"
Дата: 14 Дек 2010 16:51:56 · Поправил: Антиквар (14 Дек 2010 16:53:09)
Предлагались некоторыми фантазерами даже такие проекты, как монтирование вокруг Солнца (скажем, за орбитой Земли) огромной сферы, светопропускание которой можно менять по команде. Таким образом, предполагалось создать космический "световой телеграф" в расчете на то, что внеземные астрономы, увидев причудливо мигающую звездочку, поймут, что это сигнал от разумных существ, и возрадуются.
Дата: 14 Дек 2010 16:53:44
Чтобы понять других существ, необязательны общие интересы.
Дата: 14 Дек 2010 16:55:34
Есть неплохая книжуля Шкловского "Вселенная, жизнь, разум", доступно написано и как раз про это всё. Рекомендую.
Дата: 14 Дек 2010 16:56:47 · Поправил: RV9WMV (14 Дек 2010 17:19:11)
а при отсутствии общих интересов, это называется "привлечь к себе внимание". Чем это заканчивается я думаю обьяснять не надо )) интересы могут оказаться односторонними))
Дата: 14 Дек 2010 17:12:26
Антиквар
Учёные считают, что в нашей галактике вполне достаточно планет, похожих на нашу Землю по температуре, давлению, составу атмосферы, наличию воды .
Дата: 14 Дек 2010 17:21:16
В нашей Галактике больше 100 миллиардов звезд. Однако, у какого количества звезд есть планеты, ПОХОЖИЕ на Землю? Посмотрим на нашу систему. Атмосфера у планет земного типа, на которых нет жизни, состоит в-основном из углекислого газа (Венера, Марс). При этом давление составляет от сотых долей атмосферы (Марс), до десятков атмосфер (Венера). Температура - от -90...120 на Марсе (ночью), до +450 на Венере и Меркурии. Вода в жидком виде есть только на Земле (хотя на Марсе бывает до +20, из-за низкого давления вода лишь возгоняется от одной снежной шапки к другой).
Дата: 14 Дек 2010 17:32:55
вроде как уже выяснили, что жизнь легко и просто зарождается там где есть достаточное разнообразие, ну хотя бы химическое (другие формы жизни есть наверняка тоже, Солнце устроено посложнее чем наша Земля, и скорее всего там тоже жизнь. Проявления? навалом. Циклы например. ) Тут уже спрашивать впору, о чём мы говорим, что называем жизнью. Что называем разумом.
А так, в наших условиях, жизнь появляется и при отсутствии кислорода, (сера его замещает), и при отсутствии воды. Куда не плюнь - везде жизнь. Только по разному организована. А понятие "разум" наверно ввели масоны. (термин который навязан ибо нет точной границы что это такое)
Дата: 14 Дек 2010 17:56:37
Как то меня спросили :"Есть ли жизнь на других планетах ?" Я ответил:"100% есть и даже дофига , да что с неё толку" Вселенная бесконечна и соответственно число форм даже и разумной жизни в ней так же бесконечно. Да вот где та жизнь ? Я вообще допускаю, что есть планеты 100% идентичные Земле по видам животных , растений , народонаселению, стоящие даже на одной с нами ступени развития. Но оказаться они могут за такое число килопарсек от нас , что ещё 100 лет не будет посторен компьютер способный это число даже представить. Да хоть 10 в степени 500 миллиардов - по сути всё равно что бесконечность.
Дата: 14 Дек 2010 19:13:21
думаю что всё проще, и по другому))) пытаюсь изобразить эксперта, не пинайте). И вообще-то , самое большое число 10 в степени 100, называется Гугль (Google), это больше, чем считается есть атомов в нашей Вселенной. (10 в 29й вроде бы, всё посчитали))))... но вряд ли фишка в этом. Вы не задумывались над таким вопросом: типа я подошёл к зеркалу, тот который с той стороны, тоже одновременно подошол. Кто из нас это сынициировал первым? (слово-то какое)
